Supported browsers for the web UI
Re: Supported browsers for the web UI
Postby ianhaynes » 13 Aug 2015, 19:05
Yes I did both.
I'm seeing the same issue in all browsers, the volume control doesn't work and the buttons under the volume control have no effect, although the mute button does send the volume to zero (but no change in volume). I also notice that as I drag the volume pointer it flickers from 0 to the new values. Not noticed this before.
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby hondagx35 » 13 Aug 2015, 20:35
Postby ianhaynes » 14 Aug 2015, 09:56
The debug data is at http://pastebin.com/tuHHZ4Ca
Your help appreciated!
Ian
ianhaynes
Postby hondagx35 » 14 Aug 2015, 15:31
Postby ianhaynes » 14 Aug 2015, 22:28
Thanks for this. Using the software volume control has solved the problem.
I'm still seeing one issue in IE11 Mobile, where the queue won't scroll reliably. This wasn't there before I updated to the nightly build (which fixed the original playlist deletion problem in IE).
If you switch between the queue and playback it will scroll once but then stop. Switching like this makes it usable, so it's not a critical issue.
ianhaynes
Return to Compatibility list
