switch on/OFF PI3 + I SABRE DAC AMP + PI-SPC ATX
Postby EZJstef » 10 Dec 2017, 10:30
hi,
i have done several test, to use this power ON/OFF PCB ...
base is from i think it's the last one !
with this modif code
and try this also
i have also tried the audiophonics
and i have always the same results ..... when i pouch the button just have 2s power and stop like you can see on the beginning of video
i am wonder, what i am doing wrong !
if somebody have idea
tnx Stef
EZJstef
Re: switch on/OFF PI3 + I SABRE DAC AMP + PI-SPC ATX
Postby hondagx35 » 10 Dec 2017, 13:38
Hi Stef,
is your "button" a toggle switch or a momentary switch?.
AUDIOPHONICS recommends using a momentary type.
If you have a toggle switch try to firmly press it so it does not toggle.
Postby EZJstef » 10 Dec 2017, 14:30
hi Franck,
is momentary switch , now seems running a little with last image of feb 2017, and code modifyon power on ( still have loading start pictures) with a NO contact, no NC like audiophonics schematics says, but shutdown is only possible with more than 4s press button, no shutdown with shutdown pictures ......a other trouble also is the led of the button is flashing all times, when rune audio is running! but run and stop doing ok except this flashing light button
tnx for reply
EZJstef
Postby EZJstef » 10 Dec 2017, 15:09
when power is on :the green PI3 led also flashing, and no more red led active
for more info maybe important details
EZJstef
Postby hondagx35 » 11 Dec 2017, 00:05
Postby EZJstef » 11 Dec 2017, 08:35
Hi Frank ,
Tnx, i tried several methods, and it was so easy with the good way ........ tnx a lot
now try last things to fixe is the 7" began black screen trouble after upgraded MPD and project will be around ready to use ....
EZJstef
Postby hondagx35 » 11 Dec 2017, 12:40
is there an urgent reason for updating MPD?
I am unable to support the "addons" extention, so please ask the developer (rern) for help.
Postby EZJstef » 11 Dec 2017, 15:10
not specialy, i just try to build project with the last MPD, with youtube link nicely ..........but old version doing enough for the moment ... wife should be glad too !!!
i will waiting for some post around can talk about this problem!
anyway now i am starting the box !!!
stef
EZJstef
