TEAC AI-101DA USB working?
Postby twinpeaks » 22 Nov 2016, 11:51
I installed RuneAudio on a Raspberry 2. It's working really fine but a separate DAC is needed definitely. Since I also need a new, smaller amp (restricted space), an amp with integrated DAC would be nice. So I found the TEAC AI-101DA. I surely could use the toslink input with a HiFiBerry Digi+ or similar, but using the amp's USB port would be nicer, because no HiFiBerry is needed and both toslink inputs would be free for other sources. I couldn't find a definitive answer, does RuneAudio (or Linux in general) support the USB port of the AI-101DA?
twinpeaks
twinpeaks
Re: TEAC AI-101DA USB working?
Postby Brain007 » 23 Nov 2016, 10:09
i think you need to talk to TEAC official support!
here you go: teac.com/support
Brain007
Postby twinpeaks » 30 Nov 2016, 14:27
Although I didn't expect an answer other than "we don't support Linux" I contacted Teac service last week and asked if they know if this thing works in Linux. No answer at all until now.
I let you know should they still send a reply.
twinpeaks
Postby VW Darren » 01 Mar 2017, 22:50
I would say -yes.
I have a Teac NP-H750 which has a built in dac I connect to my RPi via a USB cable.
VW Darren
Postby ragious » 02 Mar 2017, 08:06
I would say yes to since I run an AD-301DA without problems :-)
ragious
Postby iosman987 » 17 Jan 2020, 06:23
iosman987
Postby numanair » 08 Jan 2021, 03:10
numanair
Return to Compatibility list
