Currently I have pi-hole co-installed and that gives it to me and I found vcgencmd in /opt/vc/bin so that helps.
I am running the pi 4 without a case, heatsinks installed and a pifi DAC+ hat and it runs at 34C with a fan blowing in from the card end.
Without it it runs around 44C, I think a case would make this higher plus I am in Australia and its in the middle of winter at the moment.
Max air temp at the moment is around 23C not 30C+
Running Kodi with Netflix on the pi4 resulted in 80C+ and crashing so this iteration is heat sensitive and it is recommended to have a fan
I have another post here on running runeaudio on the pi4 which has photos of my system. Amazingly the sound seems louder and clearer,
Don't know whether I am imagining that or not.
runeaudio-0-5-beta-is-running-ok-on-my-rpi-4b-2gb-t6867.html
cheers
- pi-hole temp readout
- pihole_temp.png (34.99 KiB) Viewed 10784 times
- vcgencmd measure_temp
- vcgencmd_temp.png (36.29 KiB) Viewed 10784 times
