The New 4-core Raspberry Pi
Postby hondagx35 » 06 Mar 2015, 01:30
Hi all,
here is a new . See also .
Now with:
- Spotify
- DLNA / UPnP
- Airplay
- some minor bugfixes
Airplay now with metadata (no coverart yet)
Please test and comment.
Postby Da Alchemist » 06 Mar 2015, 11:48
This Version boots up incredible fast, but i can not edit the config.txt; Errormessage is "Error writing config.txt: Read-only file system".
Btw is it possible to compile Mpd with "--enable-pipe-output"? I am using Brutefir to make some room correction, it works great on Raspbian ( I am not familar with Arch :oops: )
Da Alchemist
Postby nopphong » 06 Mar 2015, 11:57
I try new image.It work perfectly for me. Library update is very very fast i love it.
The config.txt can be edit without any problem (i use winSCP to edit)
* With powerful RasPi2 i think if set it self to be a wifi router (I mean if it can use without need of external wifi router) it will be perfect.
nopphong
Postby Da Alchemist » 06 Mar 2015, 12:11
Got it working doing "sudo umount /boot" and "sudo fsck.fat -trawl /dev/mmcblk0p1"
Da Alchemist
Postby hondagx35 » 06 Mar 2015, 12:35
Postby hondagx35 » 06 Mar 2015, 12:37
Postby f1251218 » 06 Mar 2015, 12:39
f1251218
Postby hondagx35 » 06 Mar 2015, 12:53
Postby f1251218 » 06 Mar 2015, 13:02
f1251218
Postby Da Alchemist » 06 Mar 2015, 13:13
Da Alchemist
