The New 4-core Raspberry Pi
Postby hondagx35 » 17 Apr 2015, 11:07
Postby Klausi69 » 17 Apr 2015, 19:49
Klausi69
Postby MeiT » 19 Apr 2015, 20:48
MeiT
Postby lightforms » 21 Apr 2015, 02:52
lightforms
Postby hondagx35 » 21 Apr 2015, 06:07
Hi lightforms,
in the setup i showed in post a second pi is used for the user interface.
But i'm working on a user interface for local displays (HDMI).
Postby J@r0d » 21 Apr 2015, 06:26
I use same product in my car, I control RPI by Ipadmini with wifi, Ipad is launch in hotspot
J@r0d
Postby lightforms » 21 Apr 2015, 12:51
Local display via Hdmi would be fantastic, particularly if it could be implemented with touch screen or some buttons for control.
When you say your working on a user interface is this a look thing or a menu structure?
Sorry for the dumb question I'm just interested, and not sure how this is built or structured.
cheers
Dave
lightforms
Postby Tinitus » 21 Apr 2015, 20:45
first of all a big thank you to all contributors to this thread, it has been a source of inspiration for me. Using an Odroid C1 instead of a Pi 2 (no USB bandwidth problem and Gb ethernet) I have not yet found the time to use the cookbook to build my Rune Audio from scratch, still I have one question for Frank:
Frank you build two packages for Da Alchemist in order for him to be able to implement room correction via brutefir, would it be possible to use those packages on the Odroid platform or would I need different packages
One question for Da Alchemist:
I for one would be very keen to know how your project of integrating room correction via brutefir went, could you let us know?
Tinitus
Tinitus
Postby hondagx35 » 21 Apr 2015, 21:20
Postby Da Alchemist » 22 Apr 2015, 15:10
Brutefir is running absolutly flawlessly on the Pi2 I am using it with a PCM5122 card.
I will make a short description on the "DIY and tweaks" section.
A very short Description here.: rune-audio-and-brutefir-convolver-for-roomcorrection-t1094.html
Da Alchemist
