The New 4-core Raspberry Pi
Postby TJH » 09 May 2015, 20:24
Hi Frank
I wondered how the WiFi Access point is coming on?
I've been trying to get it going but to no avail.
I've tried two main approaches, both based on hostapd-configuration-wifi-hotspot-setup-t567.html which uses the the script from github: https://github.com/oblique/create_ap
1) Start with pacman -Syu iw dnsmasq --ignore ffmpeg
then (after making tea)
git clone https://github.com/oblique/create_ap
cd create_ap
make install
create_ap -n wlan0 MySSID MyPassword
This gives an error in hostapd which I can't seem to sort out
2) Start with pacman -Sy
cd create_ap
make install
then try to get /update whatever the error messages suggest
I can't get this to go either.
I'm giving up and waiting for your bigger brain - divorce threatens!
TJH
Postby fminne » 12 May 2015, 06:27
Does anyone knows how I can activate the auto-play-at startup-function? I want to have this functionality, so that I only have to power-up my Raspberry Pi version 2 and my preferred webradio is immediately played.
This was working on a Raspberry Pi B and B+, but on a Raspberry Pi version 2 it doesn’t.
Thanks for your help, Frank.
fminne
Postby utschu » 12 May 2015, 22:52
AFAIK it works if the PI 2 is connected via Ethernet. Via WIFI it doesn't work yet.
utschu
Postby hui13 » 19 May 2015, 03:44
I have been using Runeaudio on and off since 0.1 and regularly since 0.3. Until recently I have had the DIYINHK ES9023 DAC connected via I2S to a Raspberry Pi B and it has worked great, no issues apart from the occasional hiccup with hi-res files over wifi.
I have recently switched over to a Raspberry Pi 2 and need some help with the i2s configuration. I am temporarily using a different DAC, also with the ES9023 chip. I read in this thread Darp saying that he was successful with a Curryman DAC so maybe he can offer some advice.
So far I have tried using the rpi-dac setup recommended for the PCM1794a (thought that it might work) and I am getting clear sound but also a background buzz (digital?) not present on the Pi B. Strangely I only get this with 44.1/16 FLAC and Wav files (most of my library) and not with any of my hi-res files (88.2/24, 96/24, 176.4/24, 192/24). I also do not get the buzz on the few mp3/m4a files in my library. This is when set to MPD and with software volume enabled. When set to airplay I do not get the buzz but I do get some hiss. Spotify works but I cannot verify for noise as audio is at 100 %.
BTW I had no luck getting the analog audio working either. Had it working with Volumio 1.55 but with Runeaudio very low volume sound with what sounded like digital noise. I am using image beta_20150304 with the updated kernel as per suggestion in post dated 12 Apr 2015, 15:11.
BTW, I tried recently to update through gitpull and it seems to have broken the reliability of the installation (odd behaviour requiring reboot).
Thanks.
hui13
Postby tinue » 24 May 2015, 09:41
How can I get volume control for Spotify, Airplay etc (i.e. anything but MPD)? The Pi with Hifiberry Amp+ always plays at 100%, which is a bit loud.
In MPD I can select "software" Volume Control, which then allows me to reduce the volume. I can't find an equivalent setting for Spotify, for example.
Thanks! Martin
tinue
Postby johnbanks » 29 May 2015, 22:50
Hi ...
Today I got my rig running and it sounds great - RPi2 with iqAudioDAC+ and Pi-AMP.
I like to be up to date so I did a DEV gitpull with the following result ...
A brief message:
Updated successfully then ...
Error: Your local would be overwritten by ...
Then a bunch of references ...
Please commit your changes or stash them
Aborting
Can anyone please explain? What am I not doing?
PS: And thx to all you guys who've made this happen
johnbanks
Postby Tinitus » 29 May 2015, 22:57
Hi John,
have a look here:
port-runeaudio-to-odroid-c1-arm-v7-t1102-50.html
and the following page
that might help you.
Greetings Tinitus
Tinitus
Postby johnbanks » 30 May 2015, 12:03
Hi & thx for the suggestion.
I followed the link and Frank’s suggestions and did ...
[root@runeaudio ~]# cd /srv/http
[root@runeaudio http]# rm app/libs/runeaudio.php
[root@runeaudio http]# git pull
But I got the same error messages as follows ...
Updating 077e21a..38c91fc
error: Your local changes to the following files would be overwritten by merge:
app/config/_os/usr/lib/systemd/system/shairport.service
app/config/defaults/shairport.service
app/coverart_ctl.php
app/network_ctl.php
command/airplay_toggle
command/rune_PL_wrk
Please, commit your changes or stash them before you can merge.
Aborting
Any other suggestions ... by anyone?
Thx
johnbanks
Postby johnbanks » 30 May 2015, 12:23
PS: S*it, I should not have rm'd that file
Now I cannot browse to the UI (but can still puTTy in)
So it's back to square one - burn the image and set it all up again
Hey-ho
johnbanks
Postby hondagx35 » 30 May 2015, 12:26
Users browsing this forum: Majestic-12 [Bot] and 1 guest
