The New 4-core Raspberry Pi
Postby hondagx35 » 17 Feb 2015, 18:14
Postby dwijtsma » 17 Feb 2015, 19:38
dwijtsma
Postby hondagx35 » 17 Feb 2015, 23:21
Postby FauDrei » 18 Feb 2015, 00:22
FauDrei
Postby dwijtsma » 18 Feb 2015, 12:06
I tried a USB stick to see if I had broken my USB ports, but it's ok. DAC has SPDIF out. LED is directly connected to the TE7022L and ground. Don't know how much current runs through the LED. So at work I disconnected the SPDIF LED to lower the power consumption of the DAC.
Hopefully this will do... Will also try my O2 dac this evening.
dwijtsma
Postby hondagx35 » 19 Feb 2015, 01:40
Hi dwijtsma,
any progress with your usb dac?
Postby hondagx35 » 19 Feb 2015, 01:54
Hi all,
it would be great to get more feedback from you.
During the last 3 days i registered nearly 100 downloads from
all over the world and only got 3 replies.
frank
Postby nopphong » 19 Feb 2015, 06:17
I already download package but not test it yet.Because there is Chinese new year and shop that i order Pi2 is close until 22 feb.
In my opinion separate MPD in one core is very good idea.I have friend that make fidelizer program it a program that make windows better sound by turn off process and rise priority of sound process.He said that single core is sound better than multicore because core switching make signal timing shift (sorry i am not english native so i maybe choose wrong word).
nopphong
Postby wfverkerk » 19 Feb 2015, 08:17
I managed to get the NFS drive mounted, thanks to your feedback. However, indexing the drive (building the database) does not work. An issue I had with Volumio as well, but not with Kodi. It mounts perfectly, green checkmark and all. But when I access the Network Mounts tab in the library, there's no content except for a back-button. The library icon also never goes into the rebuilding animation, as if the rebuild is done instantly.
Another thing I noticed is that I get heavy static on most radio stations. So far, I have been able to find 1 radio station that sounds normal (r10_6070s_plus). So I can confirm that the connection to my DAC works ;).
wfverkerk
Postby dwijtsma » 19 Feb 2015, 08:48
Yesterday I tried my dr. DAC nano with disabled s/pdif led. Still got 'over-current change' message 3 times per second. This DAC works with my laptop, desktop PC and the raspberry pi model B. This evening I will try if it does work with raspbian to see if it is software related somehow, because I think the DAC doesn't draw to much current...
'O2 + ODAC' works fine. When I manually select a different song there is a small glitch. Didn't notice this in between songs when playing a complete album. No idea where it's coming from. NFS works fine. Had to add the 'nolock' option to make it work. Like I said before, GUI works very extremely fast. Update library too. Especially fine for people how collect music. ;)
dwijtsma
