The New 4-core Raspberry Pi
Postby emilot » 21 Feb 2015, 22:21
Oh.... :?
Is there any chances to fix the dsd playback issue? I can see the clock ticking in UI, but no sound at all.
emilot
Postby dwijtsma » 21 Feb 2015, 22:50
There is a work a sort of workaround for it. Open the empty library screen. Open a second browser tab. Go to the playback screen. On the first browser tab the library screen is filled and working.
It's magical... :mrgreen:
dwijtsma
Postby hondagx35 » 21 Feb 2015, 23:04
Postby emilot » 22 Feb 2015, 00:11
Thanx again for your quick support. Very helpful...!!!!
emilot
Postby wfverkerk » 22 Feb 2015, 10:34
I'm experiencing extremely heavy static when playing back MP3s. Funnily enough, it also impacts the radio stations that (I presume) use MP3s for their music. FLAC & ALAC play without issues.
PI2 <USB> Rotel RA-1570
wfverkerk
Postby hondagx35 » 22 Feb 2015, 11:42
Postby emilot » 22 Feb 2015, 15:41
No problem here with MP3...
But I power my Pi2 through my DAC with an 6V 2A adaptor. I have read that the new Rasp is very demanding in power.
emilot
Postby Tom » 22 Feb 2015, 16:13
This is my first post on this Forum, so I want to thank RuneAudio authors for their astonishing product and hondagx35 for its RPi2 build and some improvements.
RuneAudio 0.3 beta is working very good and IMO better on RPi2 then older RPi (no performance issues).
I am using RPi B+ and RPi2 B connected to Burson Conductor DAC by USB input. USB module in DAC is based on CM6631A.
Both RPi with RuneAudio 0.3-beta (regular for RPi B+ (with all updates from git) and prepared by hondagx35 for Rpi2 B) had problems playing MP3 (just static sound, no music) and Hi Resolution wav files (a lot of crackles and pops), but no regular problems with 44 kHz, 16 bit FLAC files.
The fixes was
For RPI B+: old kernel (from 0.2 beta as far as I remember) and 3 additional settings in /boot/cmdline_rune.txt:
dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3
For RPi2 B: just 3 additional settings in /boot/cmdline.txt:
I isolated cpu 3 for mpd (using hondagx35 instructions) at the very beginning so i do not know its impact on system.
I hope it may help someone.
Best regards
Tom
Tom
Postby unameme » 22 Feb 2015, 17:40
unameme
Postby emilot » 22 Feb 2015, 18:28
With this plug in(http://emilles.dyndns.org/software/out_apx.html) I have the airplay feature through Foobar...and everything is okay.
With the plug in unameme mentioned and with the software "Stream What You Hear (SWYH)", i cannot find anything, too.
emilot
