The problem with CUE containing Cyrillic
Postby karejo89 » 28 Jan 2017, 13:07
Hello, please help. When I play the CUE-files containing English characters in the playlist are added all the tracks correctly. But when I try to play CUE-files containing Cyrillic nothing happens. I did the update through "gitpol" but it did not help. Please correct the ability to play CUE-files with the Cyrillic alphabet as you can. Because I have a large music library and do not want to divide it into separate files with CUE-Splitter. Thank you very much for the project)
karejo89
Re: The problem with CUE containing Cyrillic
Postby domisol » 29 Jan 2017, 10:11
Interesting point, I have problems also with some cue sheets, but we should investigate. Are the cue sheets encoded in UTF-8 or other text-encoding system ? For the moment I miss time to investigate which cue sheets from mine generate a problem.
Jean-David
domisol
Postby hondagx35 » 29 Jan 2017, 10:24
please try to convert your cue sheet to UTF-8 and report.
- use to open the file
- change encoding (Encoding -> Convert to UTF-8)
- save the file (with BOOM)
Postby karejo89 » 02 Feb 2017, 20:26
Good day! Thank you my friends for help) It work) Sorry for offtopic - please help else, how i can convert fast and more CUE files to UTF-8, may be you know very good soft for this? Thank you very much)
karejo89
