The Raspberry Pi 3
Re: The Raspberry Pi 3
Postby Dohmar » 08 Apr 2016, 15:41
Dohmar
Postby LogPi » 08 Apr 2016, 15:48
Ok. Thanks!
LogPi
Postby jakku » 10 Apr 2016, 11:01
Anyone got a problem with RPi3 stream via AirPlay ? Device not appear in airplay device selection.. Ony iPhone and my receivier...
jakku
Postby LogPi » 10 Apr 2016, 13:15
Airplay works like a charm on my Pi3.
The only problem I had with the last revision of RuneAudio was the one I mentioned earlier: music stopped after a while. But the problem was due to the use of minimserver with minimstreamer. Now that I only have minimserver, everything is ok... including Airplay.
LogPi
Postby MrDerp » 10 Apr 2016, 17:44
Well music does occasionally break up - in my case this probably due to Wi-Fi connection.
Have just discovered an interesting bug: channels sometimes change places. When you stop and play again or rewind everything gets ok. Pi3 + Iqaudio DAC+, v0.3-beta (23/03/2016).
MrDerp
Postby tobvc » 10 Apr 2016, 18:28
tobvc
Postby SimonDechain » 13 Apr 2016, 22:01
SimonDechain
Postby osanto » 17 Apr 2016, 00:22
Using my setup:
Pi 3 + Digi+
Connected with optical cabel to my Athem Amp
I tried some audio samples 24/48 - 24/96 - 24/192 - 24/352
I Have this problem, I can only receive sound on my Anthem to the max of 24/96 with the optical/digi+, if I change it to HDMI output i can receive sound on all formats but my amp only receives the max of 48 kHz (throw HDMI)
Is it the optical cable? bad quality? some limitation? I just don´t receive any sound, but the Runeaudio plays it with no problem.
osanto
Postby PeteB » 17 Apr 2016, 00:28
Postby osanto » 17 Apr 2016, 12:06
osanto
