The Raspberry Pi 3
Re: The Raspberry Pi 3
Postby hondagx35 » 01 May 2016, 21:10
Postby scan80269 » 01 May 2016, 22:57
My NAS was set up to do FLAC-to-PCM decoding because my Auralic Aries sounds better with FLAC decoding offloaded from its processor. My Pi3 and Pi2 are recent arrivals and I haven't re-configured MinimStreamer to skip FLAC decoding on their behalf. 95% of my content is Redbook 16/44.1, and I used the one DXD album I have just as a stress case for the Pi3.
I was expecting the Pi3 WiFi to be on par with an N150 WiFi dongle in performance (throughput, latency, etc.) but apparently the Pi3 WiFi is disadvantaged in some way. Unfortunately I lack the time to drill into it for better understanding, and I'm also a total Linux newbie.
scan80269
Postby GAP » 02 May 2016, 18:54
I set up my RPi 3 on Saturday.
NAS -> Pi over onboard Wifi -> Henry Audio DAC -> NAD c316cbee -> B&W 685
It worked flawlessly with my Henry Audio DAC through USB Async. Have not yet had time to listen for a longer period. I experienced some static noise during first seconds on a few 24/192 tracks. It seems like it might be wifi-related, I increased the buffer size to 4096 and buffer time to 30%, I am not sure if this was it but since then I have had no troubles *cross fingers*, or if it was just a sudden wifi instability on my network.
EDIT: Still, continuous stutter on 24/192 tracks. 24/96 works great. I will try tomorrow with a usb stick, as of now I have no real possibility to try to ethernet:(
Sounds great so far. I experience the sound to be fuller, with greater dynamics and the lows are a bit more emphasised compared to a harsher sound with the same DAC on my Macbook pro. Is this reasonable or am I just crazy?
Thank you very much for this.
Runeaudio on Raspberry Pi 3 -- Henry Audio DAC -- Primare i21 -- Bowers and Wilkins 685
GAP
Postby rocklander » 06 May 2016, 13:40
purchased some DACs from aliexpress.. work fine with this, but I noticed one of my units was producing more noise than the other.
various cable swaps and visual testing (my mixer shows signal levels nicely) and noticed that one PI was producing -70~-60db of noise, the other -40~-24db (significant difference).
I swapped the power cables and no difference.. swapped the RCA lead and boom.. the issue followed. I didn't expect the audio cable to make that big of a difference... :o
rocklander
Postby rastus » 06 May 2016, 16:00
rastus
Postby andre_chang » 12 May 2016, 08:54
My PI3 + RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img
Play file MP3 playback progress can be any forward and backward!
"But in some wav file playback, playback progress can not arbitrarily choose forward back, this function is invalid!"
This problem does not happen on Pi2. It's normal. What's the reason?
This version of the boot speed is very slow!
the last version of the Pi2 in the IP as long as the Ping can pass, the browser on the start of about 20 seconds...
"But the new version of "PI3" from the boot to the browser can open to enter the UI at least to more than 1 minutes."
andre
andre_chang
Postby rocklander » 12 May 2016, 09:58
should we post requests here?
on the client, if I'm not playing a song yet (and it's on shuffle) I'd like to be able to shuffle to the next song, even though it's not playing one.
the situation is - I have a bunch of songs in my playlist, and I'm about to hit play.. but don't want to hear the song I see up first.. want to shuffle to the next and decide if I like that one, then hit play... does that make sense?
rocklander
Postby tboooe » 12 May 2016, 15:47
tboooe
Postby PeteB » 12 May 2016, 19:09
Postby matlo74 » 13 May 2016, 07:03
hi
please find my results :
[root@runeaudio ~]# systemd-analyze
Startup finished in 4.294s (kernel) + 1min 31.236s (userspace) = 1min 35.530s
[root@runeaudio ~]# systemd-analyze blame
1.170s dev-mmcblk0p2.device
1.029s smbd.service
370ms systemd-vconsole-setup.service
344ms nginx.service
236ms avahi-daemon.service
215ms systemd-resolved.service
195ms logrotate.service
172ms rpc-statd.service
157ms systemd-udevd.service
150ms systemd-udev-trigger.service
142ms kmod-static-nodes.service
129ms tmp.mount
119ms systemd-journald.service
118ms nmbd.service
113ms ntpd.service
106ms systemd-sysctl.service
102ms sys-kernel-config.mount
92ms shadow.service
83ms systemd-tmpfiles-setup-dev.service
68ms rune_shutdown.service
67ms systemd-remount-fs.service
55ms php-fpm.service
55ms nfs-config.service
45ms systemd-user-sessions.service
38ms systemd-random-seed.service
34ms systemd-update-utmp.service
32ms dev-mqueue.mount
26ms systemd-tmpfiles-setup.service
25ms boot.mount
16ms redis.service
15ms sys-kernel-debug.mount
14ms var-log.mount
12ms rpcbind.service
6ms var-log-runeaudio.mount
lines 12-34/34 (END)
129ms tmp.mount
118ms nmbd.service
113ms ntpd.service
92ms shadow.service
25ms boot.mount
16ms redis.service
14ms var-log.mount
matlo74
Users browsing this forum: Bing [Bot] and 59 guests
