The Raspberry Pi 3
Re: The Raspberry Pi 3
Postby Dohmar » 15 Mar 2016, 07:53
Dohmar
Postby ingohz » 15 Mar 2016, 09:09
ingohz
Postby fboe » 15 Mar 2016, 17:14
fboe
Postby lukeap69 » 15 Mar 2016, 17:34
Hi Frank
Confirmed working with Pi 3. You can add Audio-gd DAC-19 for your list of compatible DAC. I will test my other DACs later.
I connected my Pi 3 via LAN cable first so I can setup the (built in) Wifi. Now, it is connected via wifi.
lukeap69
Postby hondagx35 » 15 Mar 2016, 18:43
thank you for the feedback.
To not confuse others, this is only needed when installing a Hifiberry Digi+ or DAC-Pro.
I'll take a look at the fix and if it has no drawbacks integrate it in the image.
Postby MSH » 15 Mar 2016, 19:08
As already stated by others it's also working great on my Pi-3. The fact that WiFi is now on a seperate internal bus makes it even better when playing via a USB-DAC (mine is a Audio-Gd NFB 11.32).
And as ever: boottime of Arch is great !! :-)
Thank you, Frank.
MSH
Postby PeteB » 15 Mar 2016, 19:45
Postby Discovery » 15 Mar 2016, 20:26
I'm up and running on Ethernet (I turned off the wifi and HDMI). I haven't performed back-to-back testing with the RPi 2 yet but first impressions are of an improvement in the sound. I'll confirm when I've done more testing.
The only issue found so far is that I cannot get a connection to my Synology NAS. I've used exactly the same parameters as my RPI2. I'm currently running from a USB stick. Has anyone else connected to a remote NAS?
Thanks for your efforts Frank.
Regards,
Trevor
Discovery
Postby MSH » 15 Mar 2016, 20:45
@Trevor and @PeteB:
I'm using CIFS-shares from another Linux-system (Mini-PC running KODIbuntu) without any problem. Same parameters as with my Pi-B. Also using WiFi for some time (today using RA but for 2 weeks I used modified MoodeAudio) and I experienced one or two short dropouts, I think. That may have been caused by a short drop of the Ethernet connection, but I don't know for sure. I listened for an hour now to RA and did not experience dropouts until now.
Regards, Menno.
MSH
Postby Discovery » 15 Mar 2016, 20:52
Thanks MSH.
As nothing else worked, I just deleted my original mount definition and re-entered it, using all the same parameters. It worked. I'm confused but happy...!
Discovery
