The sound keeps turning off
Postby Claus » 17 Nov 2016, 10:14
Hello, so I'm using a Raspberry Pi 3, and I'm trying to use the WebRadio feature. But everytime it finds a raido and starts playing the speakers turn off after 2 min +- and I really don't know why?
Can anyone tell me why this is happening?
Claus
Re: The sound keeps turning off
Postby hondagx35 » 17 Nov 2016, 16:34
Hi Claus,
to be able to help we need more info.
- audio output (analog, I2S DAC or USB DAC)?
- wifi or ethernet connection?
- is the UI accessible after audio stops?
- are you able to restart the stream?
Postby Claus » 18 Nov 2016, 07:55
audio output = I believe it's analog
- It's a wifi connection
- is the UI accessible after audio stop = Yes it is acessible after the music stops
- are you able to restart the stream = I can make the music play again by turning up and down the music in the UI, that makes the speakers activate again.
Claus
Postby hondagx35 » 18 Nov 2016, 15:03
Postby Claus » 21 Nov 2016, 07:39
By turning up and down, I meant the volume, you know on the Runeaudio UI there's the wheel of volume I can control. So lets say it's on 70% volume and I turn it down to 50% and back to 70% it starts the speakers again.
I haven't tested with files from USB storage but I have tried with Spotify where it worked sorta okay.
And no my speakers are not powered from usb.
Claus
