Hi All.
Strange issue that I have searched for but cant find anything remotely similar.
When using RuneAudio (latest 0.3 beta on a Raspberry Pi 3B with HIFI Berry Dac+), through IE11 (under Windows 10), the timer shows the correct time played, but the blue circle runs fast and 1/2 way through the song, it has reached its 360 degree rotation (all filled in as per image below).
Now, what is strange, is:
1) If I click anywhere on the circle, the song is cued and played and the circle times properly.
2) if I have my Android phone connected at the same time or any other device, then the blue circle times correctly on the PC running IE.
I don't use Chrome, but I did try it once and it seemed to run fine.
Is this a known issue to be fixed or do you need more info/testing?
Thanks,
Rob
