Tracks with " in the file name refuse to play
Postby mars68 » 14 Dec 2014, 18:30
I have a network mount (cifs) configured as a source.
Adding to the queue a track with a double quote ( " i.e. ascii 0x22 ) in the file name has no effect.
The track doesn't play, the playback screen shows empty title.
Renaming the file by replacing double quotes with simple quotes fixed the issue for me.
Note that double quotes in the tags are handled fine, and correctly displayed as double quotes.
So just causing issue in the file name as far as I can see.
-- mars68
mars68
Re: Tracks with " in the file name refuse to play
Postby ACX » 15 Dec 2014, 02:35
Thank you for reporting the issue. We should manage also these particular cases during the parsing in the future.
