Trouble with Spotify [SOLVED]
Postby RaspiPie » 24 Jan 2016, 14:17
Hi all
Spotify does not work for me. The folder is empty. If I search in the database I just see a spinning wheel but nothing happens for ages ( I think I waited up to 10 minutes ). Should I wait longer ?
I entered my username and password in the settings under Spotify. I have a Raspberry Pi 2 connected to a Hifiberry DAC+ light. I use RuneAudio 0.3beta. Playing audio from local USB works all right.
Thanks very much for any help.
RaspiPie
Re: Trouble with Spotify
Postby fohnbit » 24 Jan 2016, 14:24
User and password are correct?
It would be great, when RuneAudio check the Login on Spotify when saving.
I have this same Problem, but was a mistake on Password.
I'm using the nightly build and works absolute fine. Only the volume knob is disabled when playing Spotify :-(
fohnbit
Postby RaspiPie » 24 Jan 2016, 14:44
RaspiPie
Postby hondagx35 » 24 Jan 2016, 16:31
Hi RaspiPie,
with spotify you only can play and search songs from a playlist.
Login to your spotify premium account and setup a playlist and test again.
And yes, the volume knob is disabled when playing songs from spotify.
This will be changed with the next release.
Postby fohnbit » 24 Jan 2016, 17:15
Just to be sure:
You have a Spotify Premium account?
fohnbit
Postby RaspiPie » 24 Jan 2016, 19:45
Hi Frank
Thank you so much. Now I added playlists and everything works!!!! I didn't know that it only works that way. Now you have solved two problems I had. You tha man :)
RaspiPie
