Tweaking the audio performance Rpi3
Re: Tweaking the audio performance Rpi3
Postby andrea » 15 Jun 2017, 11:52
andrea
Postby pietpara » 04 Sep 2017, 22:22
It has been a while since I installed the latest image for the RaspTouch and was wondering if there is a new one and where to find it. I tried finding it on the audiophonics forum but since most is in French I couldn't find anything referring to images for the rasptouch.
Is there a standard support site for it?
Or is there a known documented procedure to install the latest from rune?
Thank you
Pietpara
pietpara
Postby Vhond » 04 Jun 2019, 11:04
Vhond
Postby Vhond » 09 Aug 2019, 14:40
I can confirm these alterations still work for beta 0.5, but it seems after every gitpull the orion_optimize.sh file is overwritten (to default)?
Vhond
Postby joe63 » 21 Dec 2020, 10:15
hello guys
I am a new user of RuneAudio and I must confess that I find it very interesting and well made, specially as for the graphic layout and effective use of functions. After these tweaks the sound perception is surely different, maybe better, I don't know exactly :P . Thanks a lot for everyone's efforts ;)
So far I have used RuneAudio 0.5b and modified the files config.txt and cmdline.txt, after that I edited the file orion_optimize.sh to change the parameters related to the sound profiles.
Now I am trying to follow the same way in Rune Audio+R e6 but unfortunately I cannot find and edit the file at issue :P
I wonder if those changes are already set in this new version. If not, how is it possible to tweak the sound profiles here? Has anyone tried them out?
thanks in advance :)
joe63
Postby cmh714 » 21 Dec 2020, 18:21
I think if you go to System and scroll down to Environment section, you can find the Sound profiles and edit them there...
GL!
