Twonky besides RuneAudio
Postby psychofaktory » 15 Aug 2015, 14:09
first: Thanks for this great piece of software!!! It's my very favorite software on Raspberry Pi.
I want to install a Twonky Server beside RuneAudio on my Raspberry Pi 2. Actually i've got the latest dev-build installed.
Which steps do i have to do, to get a working instance of Twonky?
psychofaktory
psychofaktory
Re: Twonky besides RuneAudio
Postby hondagx35 » 15 Aug 2015, 14:42
Postby psychofaktory » 16 Aug 2015, 21:37
Thanks for your quick reply!
I've found this guide .
Maybe we could adapt this for Arch Linux.
psychofaktory
Postby hondagx35 » 16 Aug 2015, 23:14
Postby hondagx35 » 16 Aug 2015, 23:40
Postby psychofaktory » 19 Aug 2015, 20:03
psychofaktory
Postby psychofaktory » 16 Sep 2015, 14:14
I did some further tests:
After editing the nginx.service-file Twonky works, but the Rune-Webserver doesn't work anymore.
If I change the ngingx.service-file back to original Rune-Webserver is working fine, but Twonky won't start at boot.
How can i get started both at boot?
psychofaktory
Postby hondagx35 » 16 Sep 2015, 15:19
Hi psychofaktory,
there is a typo from side in the above description.
To get twonky started at boot we have to edit/generate this file:
/usr/lib/systemd/system/nginx.service
nano /usr/lib/systemd/system/nginx.service
should be
/usr/lib/systemd/system/twonky.service
nano /usr/lib/systemd/system/twonky.service
Postby psychofaktory » 16 Sep 2015, 18:45
Thanks for your reply.
After my last post I searched a little bit an found out how to create a own service and how getting it start at boot.
In the end i've got it working, and what i did was exactly that what you described in your post :)
A good way to learn how the things work together.
Do you have an idea what's to do to get the latest version of Twonky running?
psychofaktory
Postby hondagx35 » 16 Sep 2015, 20:21
Hi ,
you can try this version
http://www.twonkyforum.com/downloads/8. ... -8.1.2.zip
it was published 3 days after my post.
