UI Wait on Wifi
UI Wait on Wifi
Postby ian2000t » 28 Jun 2016, 14:33
I have 2 Raspberry Pi's on Wifi both running the same build of Rune Audio (build: beta-20141027). Both on the same network and router, but both using different manufacturers of USB Wifi.
I have a problem connecting to both devices intermittently. When I load the page (by IP address) sometimes it does not connect. I have to keep refreshing the page a few times until it loads. Once it's loaded generally it works fine then on.
It's almost like the Wifi is going into sleep mode, and only listening once every couple of minutes - or something to that effect. Does that sound possible? If so, is there a Wifi setting I can change somewhere?
ian2000t
Re: UI Wait on Wifi
Postby rikardo1979 » 28 Jun 2016, 15:38
rikardo1979
Re: UI Wait on Wifi
Postby hondagx35 » 28 Jun 2016, 16:23
Re: UI Wait on Wifi
Postby popov » 29 Jun 2016, 18:34
In a other project based in archlinux, disable power management Was not suffisant.
Have a look to systemctl status avahi-daemon
If you have a mdns issue ... Verify /Var/run and /var/lock are symbolic links
the issue is that i solve it with pacman -Suy.... With is not compliant with runeaudio
I don't try to redo directly links
popov
