Unable to mount NAS
Re: Unable to mount NAS
Postby nic » 17 Dec 2013, 22:44
Last night after removing the source name , the green tick appeared . On clicking update mpd database , I get the prompt box 'mpd update , database update started' but no spinning symbol like on Raspyfi . Going to playback then browse there no source directories . I have used the reboot or power down under 'turn off' on the menu . The strange thing is I get the green tick on nas mounts no matter what fileshare protocol is used
cheers
Nic
Pi3 , Kali / Piano 2.1 (with dedicated choke input PSU) ----6SN7 beta follower---BUZ900P choke loaded source follower---Beyma 15XT in 230l cabinets/TPL150H AMT .
nic
Postby nic » 17 Dec 2013, 23:06
Now getting the same issues as before . I can access the help , credits and turn off tabs . The others when clicked result in eggtimers or 404 messages . This is on a fresh install on a fresh Sandisc SD card and started happening when trying to add a NAS source . Are there reports of others finding their Runeaudio setup works using the beta release ?
cheers
Nic
nic
Postby ACX » 17 Dec 2013, 23:30
Postby bassiedt » 18 Jan 2014, 11:27
With mpd database errors I found the following command very useful. ( maybe a good idea to incorporate it in the webUi as well)
tail /var/log/mpd/mpd.log
To have a quick look at mpd log containing all the database entries. This way I found that volumio gets stuck with certain mp3 files because it uses ffmpeg for mp3 indexing which produces an error.
bassiedt
Postby ACX » 18 Jan 2014, 17:11
Thank you bassiedt, we constantly use that command when debugging. In the near future we are going to include a handy debugging tool in the RuneUI. We already use an internal one (try point your browser to http://runeaudio.local/dev.php to see that) but we want to enhance it and make it easy to use for common users.
Postby ACX » 21 Jan 2014, 18:07
Hi nic, have you tried the 0.2-beta released yesterday?
Previous
Return to Bug report
