Thank you , I've got high hopes for this , really enjoying raspyfi and ended up building a new pair of amps especially for it
When I edit the mount point I get the following : ' Last system mount error mount.nfs: access denied by server while mounting 192.168.1.5:/public' . This exactly as I had it entered in raspyfi , I have also changed the 'p' in 'public' to upper case and still get the same error
In debug mode , see results below
Linux version 3.6.11-18-ARCH+ (nobody@) (gcc version 4.7.2 (GCC) ) #1 PREEMPT Mon Oct 21 01:15:42 CDT 2013
system load: 0.10 0.07 0.03 1/79 386
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
Advanced Linux Sound Architecture Driver Version 1.0.25.
0 [ALSA ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
bcm2835 ALSA
1 [D20 ]: USB-Audio - DIYINHK USB Audio 2.0
DIYINHK DIYINHK USB Audio 2.0 at usb-bcm2708_usb-1.3, high speed
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
Pi3 , Kali / Piano 2.1 (with dedicated choke input PSU) ----6SN7 beta follower---BUZ900P choke loaded source follower---Beyma 15XT in 230l cabinets/TPL150H AMT .
