Updating library causes memory to fill up
Postby sfgreenwood » 27 Mar 2016, 13:39
I've installed 0.4 beta on an 8Gb SD on a Raspberry Pi 3. I have two music libraries on NFS mounts and initially tried to scan them both but this causes the Pi to become unresponsive and to require a restart, which means that the library isn't saved. I then dropped one of the mounts and tried scanning the remaining one, and while the Pi and the UI's response drops right off I could at least confirm that it's a memory problem. Unfortunately this seems to be a problem with mpd and large libraries and there doesn't seem to be an answer in the mpd configuration. Has anyone got a method of handling a large library in a more effective way?
sfgreenwood
Re: Updating library causes memory to fill up
Postby hondagx35 » 27 Mar 2016, 13:59
Hi sfgreenwood,
please post the following info:
- output from "df -h"
- output from "free"
- what is a large library?
Or even better post your debug data as mentioned on the "Post a reply" page.
Postby sfgreenwood » 27 Mar 2016, 15:52
The update has finished now and memory has freed.
df -h
/dev/root 7.1G 1.6G 5.2G 24% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 12M 450M 3% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 4.0K 462M 1% /tmp
logs 5.0M 40K 5.0M 1% /var/log
rune-logs 5.0M 2.7M 2.4M 53% /var/log/runeaudio
/dev/mmcblk0p1 100M 18M 83M 18% /boot
192.168.1.125://export/flacs 3.7T 1.8T 2.0T 47% /mnt/MPD/NAS/Flacs
free
total used free shared buff/cache available
Mem: 944812 93908 656880 18308 194024 735264
Swap: 0 0 0
However, when I was writing the post it was this:
free -m
Mem: 922 838 42 17 41 9
Swap: 0 0 0
The library is about 500Gb of flacs and 300Gb of mp3s.
I've added the mp3 mount back and the updater is running again and slowly using up memory but the library now seems to have saved to the database so it should be persistent.
As I say, this is probably an issue with mpd rather than Rune.
sfgreenwood
