Upgrading hardware to avoid glitches / clicks / pops
Postby james_b » 23 Oct 2015, 22:06
I'm really happy with my rune audio setup using a Raspberry Pi model B, but the playback could be better. I get clicks and pops at least once on most 44.1khz flacs and more than this on 88.2k or 96k flacs but it's just about tolerable. At 192k it's a big problem.
Would switching the Pi model B for a Pi 2 go some way to rectifying this, or would one of the other hardware options be the more powerful device? Is I'd be happy to upgrade to whichever would give me the best playback.
thanks
james_b
Re: Upgrading hardware to avoid glitches / clicks / pops
Postby Beelzebassie » 24 Oct 2015, 10:18
Hmmm... My Pi B+ only uses about 4% of its capacity (USB) while playing 16_44.1 files, and 10% @ 24_96 (over I2S, when using USB it goes up to 45%).
Beelzebassie
Postby james_b » 25 Oct 2015, 19:21
james_b
Postby Beelzebassie » 27 Oct 2015, 11:01
Have you tried monitoring the activity on your Pi?
I use Putty to connect to RuneAudio, and the Linux 'top' command to monitor my Pi.
Beelzebassie
