Upnp/dlna avaible only with ethernet (solved)
Postby ciccio840 » 31 Aug 2016, 15:39
I've a problem with my raspberry pi b and the upnp/dlna streaming, when i use the wifi device (instead of ethernet) the upnp/dlna feature not working.
The wireless lan work properly and is correctly associated to my network.
Why did not working?
ciccio840
Re: Upnp/dlna avaible only with ethernet
Postby hondagx35 » 31 Aug 2016, 20:46
Hi ciccio840,
to help we need more information.
- RP1, RP2 or RP3 (all are available as type B)?
- If it is a RP1B, is it updated to the nightly builds?
Postby ciccio840 » 31 Aug 2016, 23:49
Thanks for reply,
The raspberry is the first version model b, i don't know if the runeaudio is the nightly one, I've downloaded yesterday the last version from the download section: 0.3-beta.
ciccio840
Postby hondagx35 » 31 Aug 2016, 23:52
Postby ciccio840 » 01 Sep 2016, 00:02
Yes it isn't :D , so i try this solution and i tell you later. Thanks!!
ciccio840
Postby ciccio840 » 01 Sep 2016, 11:55
I follow the steps for the nightly update. Nothing change. :cry:
ciccio840
Postby hondagx35 » 01 Sep 2016, 14:33
Postby ciccio840 » 01 Sep 2016, 14:41
I've tried, but the config file is not located in /etc, but in /usr/etc.
I added this option, but nothing change.
It's strage because the cable is not plugged in and in network config from Rune UI display that the eth connection is down but inside eth menu the status is up with 10 mb/s connection... :?:
ciccio840
Postby hondagx35 » 01 Sep 2016, 20:38
Postby ciccio840 » 02 Sep 2016, 10:28
Finally works... The problem was my wifi usb device... I don't know why!! I changed the wifi device with a newer one and now works.
Thanks for all support.
ciccio840
