Upsampling
Re: Upsampling
Postby Audiotone » 18 Jul 2016, 21:21
Would be much better if this option could be set in mpd setting menu...
Any chance this would be implemented soon? This is the only issue that would keep me (and a lot of audio freaks like me) away from rune audio...
For the rest...just perfect!
RPI 3, Concero HD
Audiotone
Re: Upsampling
Postby hondagx35 » 18 Jul 2016, 22:55
Re: Upsampling
Postby Audiotone » 19 Jul 2016, 12:53
RPI 3, Concero HD
Audiotone
Re: Upsampling
Postby rikardo1979 » 19 Jul 2016, 13:48
rikardo1979
Re: Upsampling
Postby hondagx35 » 19 Jul 2016, 17:12
Re: Upsampling
Postby nbnb » 19 Jul 2016, 22:49
i'll answer for my case: i have a (high quality) audio interface which has an s/pdif input that accepts a fixed sampling rate only. i use hifiberry digi+ to feed that. so i have no option for 'bit-perfect' playback, i need to resample.
i admit that this is maybe not the most common situation. so editing config files is totally ok for me -- if the info can be found. (i did it for mpd, which works fine. i still have not been able to make it work for shairplay playback though, could not find the info)
nbnb
