USB Audio Low volume
Postby Toube » 10 Oct 2018, 08:21
Hi guys,
firstly I'd like to thank you for providing such an innovative and beautiful application for playing music.
I really like the UI, I firstly tried the Pi MusicBox but it was just not my thing.
Sorry for being lazy and not searching through the forums.
I'm using the release version: 0.4b (build: 20170229) on a Raspberry Pi 3
I have a Asus Xonar U7 MK2 usb sound card and it works really well but I get a bit of low volume with it.
Tried using alsamixer through terminal, but it doesn't seem to be doing anything.
I have hardware volume enabled in the settings.
Is there anything I can try to get the volume a bit louder?
Debug output:
https://pastebin.com/WDvgs09p
Regards and many thanks.
Toube
Toube
Re: USB Audio Low volume
Postby Toube » 10 Oct 2018, 13:48
I tried to follow this: volume-low-with-iqaudio-dac-t2861.html
How do set the volume level in alsamixer? If I use arrow up keys for each channel the volume will increase but the volume know on the UI show totally different value than the alsamixer. How can I get the volume know in the UI to be in sync with alsamixer volume?
Toube
Postby Toube » 10 Oct 2018, 14:05
if I use amixer to set volume for like 60% it will print out the following:
amixer -c 0 set PCM 60%
Simple mixer control 'PCM',0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 77 [61%] [-50.00dB] [on]
Front Right: Playback 77 [61%] [-50.00dB] [on]
Rear Left: Playback 77 [61%] [-50.00dB] [on]
Rear Right: Playback 77 [61%] [-50.00dB] [on]
Front Center: Playback 77 [61%] [-50.00dB] [on]
Woofer: Playback 77 [61%] [-50.00dB] [on]
Side Left: Playback 77 [61%] [-50.00dB] [on]
Side Right: Playback 77 [61%] [-50.00dB] [on]
This will also show the UI volume with 61 as volume.
Toube
Postby Toube » 11 Oct 2018, 06:51
Let me rephrase my question.
How can I set the volume control knob in the UI so that it matches the alsamixer settings. Now it seems that when turning the UI knob to 40 % it is the same as the alsamixers level 5db and there is barely any sound. Is it possible to make it produce sound when turning the knob from 0% and upwards?
Toube
Postby hondagx35 » 11 Oct 2018, 17:04
please try:
- set software control
- turn up the volume to 100%
- set hardware control
Postby Toube » 11 Oct 2018, 17:42
Toube
Postby Toube » 12 Oct 2018, 07:23
all working after I updated the mpd using the addon.
Regards,
Toube
Toube
Postby Toube » 12 Oct 2018, 09:23
Toube
