USB drive mounted as read-only...
Postby ghashul » 14 Aug 2014, 23:38
ghashul
Re: USB drive mounted as read-only...
Postby cmh714 » 15 Aug 2014, 00:52
Postby ghashul » 15 Aug 2014, 08:37
Thanks a bunch, that did the trick :D
ghashul
Postby rocklander » 29 Jun 2017, 13:42
I've hit this issue twice now and the fix listed has not helped.
I'm using an adata DashDrive Durable UD310 Flash Drive, 16GB, USB 2.0, Black
(https://ascent.co.nz/productspecificati ... mID=416167)
I have sent one back for replacement some months ago as it suddenly became read only.
now it's happened again. I use the same drive in other systems (a mixer and my laptop) and never an issue, but for some reason after being used in the raspberry PI running runeaudio it suddenly becomes read only.
changing the /etc/udevil/udevil.conf has not helped
(it already had 'rw' for default_options_vfat and default_options_exfat, although default_options_hfsplus was set to 'ro', but even after changing that (and restarting the udevil service) it remains read only.
any thoughts?
rocklander
Postby hondagx35 » 29 Jun 2017, 15:26
