USB exFAT Device
USB exFAT Device
Postby Velociraptor » 16 Jan 2016, 17:54
Hi I have tried to use an exFAT formated device but it did not work did an NTFS and than it worked ... would you include exFAT in 0.4 or can I easily do some OS installation on the ARCHlinux?
Velociraptor
Re: USB exFAT Device
Postby Orion » 01 Mar 2016, 00:47
Hi Velociraptor,
exFAT should be ok also in 0.3 version, maybe something could be broken in the platfrom release you are using.
What is your platform? Rpi2? All the next versions will have extFAT support.
Ciao.
Simone.
- Embedded Hi-Fi music player
Orion
Postby hondagx35 » 01 Mar 2016, 07:27
on the Pi2 exFAT should work.
What you can try is to install FUSE see .
Postby Velociraptor » 12 Mar 2016, 17:43
HI!
sorry for the late response I am using an old RPi1 since I bought an Hifiberryboard for it and it is getting older :)
bye
Velociraptor
Postby hondagx35 » 12 Mar 2016, 21:55
did you try to install FUSE?
