USB HDD makes strange sound when raspberry is shutdown
Postby Hubble49 » 05 Nov 2015, 17:50
When I shut down or reboot my raspberry over the web UI the connected USB HDD (I tried several 2.5 " HHDs to rule out defective hardware) produces a sharp "clack sound". This does not occur when I use the unmount function under sources in web UI before shutdown. It doesn't matter if I connected the HDD directly to the PI or via powered USB hub.
Is it possible to automatically unmount the HDD before shutdown?
I'm using a PI 2 and the newest version of runeaudio (updates already installed).
Apart from that Runeaudio works absolutly perfect.
With best regards
Hubble49
Hubble49
Re: USB HDD makes strange sound when raspberry is shutdown
Postby hondagx35 » 05 Nov 2015, 19:18
Postby Hubble49 » 15 Nov 2015, 18:25
Dear Frank,
thank you for your solution. It works perfectly.
With best regards
Hubble49
Hubble49
Users browsing this forum: No registered users and 42 guests
