USB-HDD not mounted
USB-HDD not mounted
Postby nixda » 02 Jun 2016, 09:14
after I re-installed rune, the usb-disk, that worked flawless in the past, is no longer recognized.
The little pop-up window* appears ("usb connected / disconnected") but it´s not shown in library or sources. ( i.e. usb stick works).
I tried different cables, rune 03 and 04, connecting before and after booting rune etc.
Of course automount is on.
What can I do to get this HD working with rune again?
What is the recommended time to connect usb-devices (before rune/raspi is powered or when it´s already running)?
big thx
[Setup is 3,5hdd 1TB + RB Pi3 + FiioE17]
* in the "connect" pop-up, there are tiny play/pause icons - to what?
nixda
Re: USB-HDD not mounted
Postby nixda » 03 Jun 2016, 16:29
nixda
Postby PeteB » 03 Jun 2016, 18:15
Postby hondagx35 » 03 Jun 2016, 21:44
Postby nixda » 04 Jun 2016, 08:51
thanks for the replies,
the 3,5" is with power supply (of course) and worked on the RB in the past (and always on pc)
I tried a 2,5" (without psu) and that works, too - actually only when connected before booting rune.
But RB get pretty warm (?)
I´ll try volumino, moode and older rune these days, just to see if the 3,5" hd stays invisible....
@PeteB
the tiny icons appear if you hit the pop-up ;)
nixda
Postby PeteB » 04 Jun 2016, 16:20
Postby albert6720 » 20 Jul 2016, 17:33
I have these unmounting issues at start then i check it to a tachnician who resolve the issue and now they working perfect from last three months.
albert6720
Postby vikassm73 » 16 Aug 2016, 11:38
Mounting and Unmounting happens if your File System is corrupt. In that case, connect HDD to any windows machine. If it has a problem, It will popup file system error Also It will help us to correct the same.
vikassm73
Postby Kassia » 21 Jan 2020, 07:23
Hello, I have met a similar situation, and my solutions are here, hope they can also help you:
1. Repair USB Root Hub:
Step1: Press Win+R and type devmgmt.msc and then open Device manager of your computer system.
Step2: Look for “Universal Serial Bus Controllers” and click on it to expand the list.
Step3: Now, search for “USB Root Hub” option and right click on it to select the properties.
Step4: After this, open “Power Management” option to uncheck the option “Allow the computer to turn off this device to save power” and press “OK”.
2. Re-install USB device driver
Step1: Go to Device Manager.
Step2: Search for the option “Universal Serial Bus Controllers”, right-click on “USB drivers”, and then click on “Update Driver Software”. Do this for all USB drivers by selecting them one by one.
Step3: Now, restart the computer system.
And I also met data loss on my hard drive, I used the Bitwar Data Recovery to recover my deleted files, if you also meet the issue, you can use this tool.
Really hope it can help you.
Kassia
Postby J4K » 25 Jan 2020, 11:15
Hi lnixda,
Just on the off chance, Connect your hdd to a computer and make sure that the Drive letter is still assigned. if not, then Assign the drive letter. I'm on rune 4 and occasionally rune/rpi will lose the drive letter and the usb drive will not show up in the Library.
J
J4K
