USB HDD spindown
USB HDD spindown
Postby leeshep » 29 May 2015, 21:16
Can someone please help me configure my USB hard drive to spindown when not in use. I really don't think it's doing it any good running all the time.
Lee
Ps I'm using beta 0.3 on a rpi2
leeshep
Re: USB HDD spindown
Postby hondagx35 » 29 May 2015, 21:35
Hi Lee,
as far as i know is the only thing that works.
Postby leeshep » 02 Jun 2015, 20:26
Thanks Frank,
That looks like just the ticket. Can you give me an idiots guide to how to install and run it please?
Many thanks.
Lee
leeshep
Postby Tinitus » 02 Jun 2015, 20:50
Tinitus
Postby Tinitus » 03 Jun 2015, 21:07
Tinitus
Postby hondagx35 » 03 Jun 2015, 21:57
Hi Tinitus,
the best way is to use udev like described
Postby Tinitus » 04 Jun 2015, 20:28
Tinitus
Postby Tinitus » 04 Jun 2015, 20:59
omiting the -B option from the udev rule did not solve the problem, it still does not work.
Starting hdparm and setting the spin down to 5 min works fine. I guess the problem with the udev rule is either the path to hdparm or the fact that hdparm does not belong to the correct user group or something like that.
Tinitus
Tinitus
Postby hondagx35 » 04 Jun 2015, 21:29
Postby Tinitus » 04 Jun 2015, 22:58
so it does in my installation, too now. I realise that using GUI for a long time cripples ones attention to details, if there is only a virtual button to press, the mouse pointer leaves some margin, is you forget " at the end of a command line it just does not work.
Thanks for your help
Tinitus
Tinitus
Users browsing this forum: Bing [Bot] and 9 guests
