VANA compelte streaming system for RPI and other SBCs
Re: VANA compelte streaming system for RPI and other SBCs
Postby Yatsushiro » 02 Nov 2016, 21:40
A bit later than planned, but here are my initial thoughts.
But first, a little background...
I started my RPi Audio journey earlier this year (having never done anything remotely like it previously) with the following:
RPi 1 Model B NAS, running OpenMediaVault over ethernet
RPi 2 Model B, intially with an IQAudio Pi-Dac+, but now with a MamboBerry LS Dac+
YJ Blue TPA3116 amp
Mission 760 speakers
Rune (After starting off with Moode)
I played with some other 3116 amps, then tried a couple of TDA7498s before settling on a modified Audiobah clone. All of this so far was undertaken with little expenditure, as the amps are so cheap.
By now I was very happy with what I had, but the upgrade itch never stops, so I brought some Q Acoustics 3020 speakers, I was now content, and enjoying my music collection much more than I ever had before.
Frequenting a collection of HiFi/Audio fora (diyAudio, Art Of Sound, Audiokarma etc) I became aware of the Allo product range (http://www.allo.com/sparky/index-audio.html); I now have a complete Vana system to build. Before I go that far, however, I wanted to try the Kali reclocker in my current setup, as it is an iteration and any improvement should be readily identified.
The Kali board itself is of a higher quality than a lot of the amps I have bought, neater soldering, components aligned etc. It fits between the RPi and the Mamboberry, using it's own power supply (5v 3A). A jumper on the Kali allows you to power the RPi via the Kali. I decided to power the RPi indepently from the Kali.
Once everything was connected up, I, with some excited anticipation, switched everything on and played some of my favourite 'test' tracks:
Dire Straights - Alchemy
Buggles - Video Killed The Radio Star
Focus - Sylvia
The Who - Baba O'Riley
Sparks - Barbecutie
Mike Oldfield - Tubular Bells
Neil Young - Harvest Moon
Delibes - Flower Duet
Now, if you read some of the other reviews, people have invariably waxed lyrical about the improvements the Kali brings; let me say it's all true. My music has never sounded so good. It's hard to describe, and possibly harder to quantify, but I can sum it up as 'more'; more detail, more expression, more enjoyment.
I'm now intrigued to try the Piano Dac in place of the Mamboberry, the Volt in place of the Audiobah clone; the possibilties and combinations are numerous. For now, though, I'm going to enjoy my 'new' system.
As long as your Dac will work alongside the Kali, it's a must have upgrade...
Yatsushiro
Postby dror » 14 Nov 2016, 07:55
Really nice.
Thank you for sharing your impressions.
dror
Postby matlo74 » 20 Nov 2016, 08:46
Thanks. It sounds interesting.
matlo74
Postby Blackfear » 20 Nov 2016, 09:57
Blackfear
Postby matlo74 » 21 Nov 2016, 10:00
I wonder what could be interesting to take ? I have today a digi+ with a class d fx audio 802.
Mat
matlo74
Postby Audiohrdwr » 21 Nov 2016, 16:19
nice to see the positive feedback.
keep in mind that the KALI will work with the DACs that run in slave mode (that dont have on board clocks)
Audiohrdwr
Postby Blackfear » 21 Nov 2016, 22:17
Blackfear
Postby Vinboy » 22 Nov 2016, 15:27
Vinboy
Postby Blackfear » 22 Nov 2016, 15:41
Blackfear
Postby Vinboy » 22 Nov 2016, 16:01
Vinboy
