Now officially supported Cubietruck (Cubieboard3)
Cubietruck related support
Re: Now officially supported Cubietruck (Cubieboard3)
Postby Zephram » 08 Jul 2015, 20:06
Is it possible that the automount feature generally doesn't work on CT yet?
Zephram
Postby Zephram » 09 Jul 2015, 19:21
Okay, that was my bad. It does the trick.
Because you asked: PSU issue.
Zephram
Postby Zephram » 11 Jul 2015, 18:54
It might be of interest for some of you that Runeaudio on CT actually plays DXD files (352 kHz / 24 Bit) without problems via a suitable USB DAC :geek:
Zephram
Postby ACX » 13 Jul 2015, 23:43
Postby JeffD » 14 Oct 2015, 20:44
Thank you for your effort and knoledge in runeaudio.
I have a problem mounting my pc network drives booting from nand. SD is fine. I get an error: Couldn't chdir to /mnt/MPD/NAS/Redbook: No such file or directory
Playing with the advance setting doesn't help either
With SD no problem:
system: win7
regards Jeffrey
JeffD
Postby hondagx35 » 14 Oct 2015, 22:37
Postby JeffD » 16 Oct 2015, 08:10
That did the job Frank!
Thank you!
Regards Jeff
JeffD
Postby JeffD » 26 Oct 2015, 22:27
I have the same problem with wlan. It picks the signal, says I'm connected but on the network page it says I don't have a connection. Ones I had a connection and it worked fine... That was once.
Can I setup network manual via terminal?
Regards Jeffrey
JeffD
Postby hondagx35 » 08 Nov 2015, 23:37
Hi Jeffry,
please post your debug data.
Postby JeffD » 13 Nov 2015, 10:51
JeffD
Return to Cubietruck
