Wolfson Audio Card patch for RuneAudio
Re: Wolfson Audio Card patch for RuneAudio
Postby surfninja » 16 Apr 2015, 15:52
Stefan, you need to determine where you copied the files.
putty into your pi and type 'ls' to list the files in the home directory. Hopefully you will see your files you copied over. if not, try 'ls /' to list the files in the file system root directory. if you still can't find them, you might need to use the command find to locate the files. Something like
find / -name Playback_to_Lineout.sh -print
you may also need to chmod the files but that was covered above.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby runaway » 16 Apr 2015, 21:35
Thanks man! The search for the file did the trick, it was in /boot/root/use_case_scripts/Playback_to_Lineout.sh (no idea why, guess all the Linux-freaks know...). So I am holding my thumbs that these settings will survive a reboot ;)
runaway
Postby translux » 31 Aug 2015, 04:33
I have Pi B with a Wolfson card and have installed Rune v0.3-beta (29/10/2014).
I'm up and running and selected the Linux kernel 3.12.13-rt and rebooted.
I created a directory and copied the scripts root/use_case_scripts/Playback_to_Lineout.sh
Ran [root@runeaudio ~]# ./Playback_to_Lineout.sh and a bunch of txt ran by.
Refreshed and checked the web ui and the I2S drop down is grayed out.
I rebooted and same results.
I tired created the recommended cron job but when I run crontab –l I see nothing.
Any guidance would be greatly appreciated.
Thank you
TL
translux
Postby translux » 31 Aug 2015, 05:13
Hum reseated the Wolfsen card an how I have sound.
I may have missed it but the Wolfsen card option should NOT show up?
I'm trying to use this as an all-in-one solution for headphones.
Is there anyway to enable volume control?
Thank you
TL
translux
Postby bone330 » 22 Dec 2015, 21:34
Just a heads up: The 4.1.13+ kernel posted here works perfectly with my Runeaudio installation (rpi B, Wolfson card):
http://www.element14.com/community/mess ... 405#167412
bone330
Postby gvasco » 04 May 2016, 17:24
Hello! This post has been inactive for a while but I hopefully someone will be able to answer my query.
I recently got a CirrusLogic DAC for my old RPi B+ which got replaced by a RPi3. Decided to instal RuneAudio as it was the only one that offered out of the box compatibility. However, I've ran into a couple of problems.
With RuneAudio 0.3 once I switch the kernel to the proper Kernel for the DAC the OS seems to start fine but I stop having network and USB devices. Has anyone else had this issue? Am I missing something that's breaking functionality?
Decided to try the 4.1.13+ kernel mentioned on the last post as well, and while that brings back Network and USB it seems to brake the RuneUI, as when I try to access it I get an http 403 error. Any chance of getting more detailed instructions on how to make this work properly?
gvasco
Postby advr61 » 21 Jan 2017, 10:02
It's my first post on this forum but reading it for a longer time.
In the past days I am trying to re-use my Rasp B+ with the Wolfson card which I didn't used for a longer time of period. I have several versions so I know a bit how it works.
I installed Rune Audio kernel for the Wolfson card.
Tried many thing and search the internet but I can't get rid of the:
amixer: Cannot find the given element from control hw:0 error.
Here and there the problem was a broken card.(which of course is possible) but are there any other reasons I get this error?
Only the green light on the Wolfson is shown.
Thanks!
Ad.
advr61
Postby gvasco » 22 Jan 2017, 15:01
gvasco
Postby advr61 » 02 Feb 2017, 10:32
advr61
