IPv6 support Pi2 Image
Postby fohnbit » 26 Jan 2016, 16:24
fohnbit
Re: IPv6 support Pi2 Image
Postby fohnbit » 26 Jan 2016, 16:29
fohnbit
Postby hondagx35 » 26 Jan 2016, 17:04
Hi fohnbit,
please can you explain the reason why you need ipv6 enabled.
Postby fohnbit » 26 Jan 2016, 20:29
Because our control unit of the house work when possible on IPv6.
The benefit is, that you don´t "need" a IP Adress ... we connect link local ... and so neither the control unit or the RuneAudio Player has to setup in detail any Ip configuration.
it´s more easy and each hardware has with link local his own unique IPv6 address.
I print the IPv6 as QR Code on the housing and with the smartphone you can scan and must not type :-)
fohnbit
Postby Orion » 29 Jan 2016, 15:12
- Embedded Hi-Fi music player
Orion
Postby fohnbit » 01 Feb 2016, 06:51
Hi Simone,
ok, so it is not possible to enable it on my raspberry after install the image?
Thanks!
fohnbit
