Playlist question
Re: Playlist question
Postby washburn_it » 13 Feb 2016, 13:52
after some time I tried to do what suggested but no one of the suggested things worked.
I tried to delete the mpd state file (with the instruction of the above posts) but it didn't work.
I tried to delete everything in "/var/www" to update to the latest nightly but it didn't work.
I checked the content of the mpdstate file but even if the track playing was the #3, after I turned off and then on in the state file the parameter "current" is 1 and, in fact, after the reboot the playlist started from #1 again instead of #3.
I tried to install everything to a PI2 and the problem is not present, so it seems that it is affecting the B+ version (at least for me).
I'm currently using a B+ with 0.3-beta version (build 20141027), RuneUI 1.3.
What can I do?
Thanks, regards.
Roberto
washburn_it
