Adding files to Mounted USB Drive
Postby Vatternish » 28 Feb 2016, 16:51
Hi all,
I'm trying to add new music to my usb drive without having to remove it from my nice amplifier box that I have everything housed in. I've searched the file structure of the Raspberry pi with Winscp but I can,t see the usb hardrive. Is it possible to see and search the drive while its mounted so that I can transfer new music? Where would the USB drive be on the Pi file structure?
Im using a Raspberry Pi with Digiamp and RuneAudio.
Thanks in anticipation
Vatternish
Re: Adding files to Mounted USB Drive
Postby hondagx35 » 28 Feb 2016, 23:55
Hi Vatternish,
it is /mnt/MPD/USB.
The USB drives are mounted read only, so you have to change this.
Please search the forum for this subject.
Postby Vatternish » 29 Feb 2016, 21:08
Thanks Frank, I will do a search.
Paul
Vatternish
Postby Grundgütiger » 02 Mar 2016, 19:30
Grundgütiger
Postby dunghnguyen » 26 Mar 2016, 16:41
This is the link viewtopic.php?t=2869
dunghnguyen
Postby Grundgütiger » 26 Mar 2016, 17:44
Good this came up again. :)
Only today I tried this as I wanted to add some music to the USB drive. I switched on the dev-mode (which I forgot to mention in my above answer) and changed the settings in the udevil.conf file to rw. Mounting the Raspberry with the Mac's Finder still doesn't let me access the USB drive because I don't have the rights doing so. Pathfinder (another Finder app) shows I have all the rights to do everything.
Thanks for any help!
Grundgütiger
Postby dunghnguyen » 26 Mar 2016, 17:49
I tried the instruction from @hondagx35 successfully. Note the type of format should be taken attention (vfat, exfat,...) to know by using the command blkid ... am I right? ... I am learning :)
dunghnguyen
Postby Grundgütiger » 26 Mar 2016, 17:59
I know. My USB drive is vfat format. Right now I have switched all file formats to rw in the udevil.conf file. 8-)
Grundgütiger
Postby PeteB » 26 Mar 2016, 18:34
PeteB
Postby Grundgütiger » 26 Mar 2016, 19:29
Grundgütiger
