Loading a new song during playback glitches
Postby Elliott B » 15 Jan 2014, 11:28
If I am in the middle of playing a song, then I double-click a new song from the browser, the new song starts playing with horrible glitches. It can be fixed by pressing pause, then play.
Elliott B
Re: Loading a new song during playback glitches
Postby ACX » 15 Jan 2014, 14:34
Can you tell me which USB interface are you using?
Have you tried the "Cmedia Fix" under MENU > Settings?
Postby Elliott B » 15 Jan 2014, 19:00
I'm using the Pi's built-in analog output.
Elliott B
Postby ACX » 16 Jan 2014, 09:10
Ok... that's a problem we were trying to solve in the last days, I suspect it has something to do with ALSA configuration or drivers. Any ideas about how to solve it quickly? (and avoid us the investigation...)
Postby Elliott B » 16 Jan 2014, 19:28
Nope, sorry. I'm very new to both RPi and MPD. I'm learning everything as quickly as I can.
Elliott B
Postby ACX » 17 Jan 2014, 00:18
Ok don't worry, we are looking for a clean solution to the problem. Any further suggestion is appreciated anyway :)
Return to Bug report
