Beginner's help required - Cannot connect to web UI
Re: Beginner's help required - Cannot connect to web UI
Postby dunghnguyen » 09 Mar 2016, 15:33
Now when listening music I found out the signal is quite weak compared to CD, other players. Any tweaks needs to make signal louder? Let me to find the related topic to raise this in. Tks.
dunghnguyen
Postby PeteB » 09 Mar 2016, 16:16
PeteB
Postby dunghnguyen » 09 Mar 2016, 16:24
I tried both analogue even HDMI but when listening I had turn vol quite much. Rough comparison with the loud level to laptop it is just 40%
dunghnguyen
Postby dunghnguyen » 10 Mar 2016, 07:37
@hondagx35: finally I got the Rune UI app on android smartphone running well. When installed I was not aware of its another screen by sliding left to right. Tks.
dunghnguyen
Postby dunghnguyen » 10 Mar 2016, 07:43
dunghnguyen
Postby dunghnguyen » 10 Mar 2016, 07:45
Bonus :)
dunghnguyen
Postby PeteB » 10 Mar 2016, 16:08
The analog output of a Pi can only drive very simple headphones, or a line input of an amplifier or preamp. It does not have enough power to drive even small speakers well. So when you connect speakers to the analog output, and the volume may seem very low.
Compared to a Raspberry Pi, a laptop has much more power available.
To drive even small speakers properly, you may need an amplifier, not just a dac. For example the HiFiBerry AMP+, or the IQAudio amp.
PeteB
Postby dunghnguyen » 10 Mar 2016, 17:55
@PeteB: I appreciate for your advice. The speakers on my pic is the amp integrated one so don't worry about that I am also aware what you concerned. Anyway the volume level of headphones 3.5mm is quite low, even its quality sound is so bad (even I used a battery to eliminate noise, etc..) so I decided to order for a HifiBerry Dac+ pro ...you don't stop me, do you? :)
dunghnguyen
Postby hondagx35 » 10 Mar 2016, 18:11
Postby PeteB » 10 Mar 2016, 22:11
PeteB
Users browsing this forum: No registered users and 43 guests
