Audiophonics I-ES9023 Sabre DAC V3 TCXO Raspberry Pi 2,0 A +
Postby G*3AS@MCrD%8^np$b9fk » 10 Mar 2016, 17:09
I2S driver : Hifiberry (volumio)
Advanced Power Management Script.
http://forum.audiophonics.fr/viewtopic.php?f=4&t=1578
i ordered this dac (on its way).
is it possible to use this script with rune audio?
(like it more than volumio)
if so, how?
thanks
ww
Re: Audiophonics I-ES9023 Sabre DAC V3 TCXO Raspberry Pi 2,0
Postby otec » 10 Mar 2016, 18:09
Yes. I have V2 and it works perfectly fine.
Sent from my Nexus 6P using Tapatalk
otec
Postby hondagx35 » 10 Mar 2016, 18:24
Postby G*3AS@MCrD%8^np$b9fk » 10 Mar 2016, 21:13
thanks for the quick reply.
Postby G*3AS@MCrD%8^np$b9fk » 16 Mar 2016, 22:18
just an update. I have received the dac. works fine. the script is not really needed. the possibility to use a powerbutton is a great thing (no need to pull/plug the usb cable). if someone is looking for a i2s dac - i recommend it (i am not affiliated to audiophonics.fr).
Postby Baldgreene » 26 Mar 2016, 23:22
Dear all,
Having this DAC and a RPI 3 (they work fine together), I have tried to enable the power management feature of the board.
Starting from the , I managed to monitor the hardware power switch through a systemd service, as described . Power Down from the GUI was properly taken into account by adding the GPIO shutdown sequence at the the RuneAudio shutdown script, . Consequently I am now able to drive a clean power off from both the hardware switch and the GUI.
However it seems that /var/www/command/rune_shutdown is also called when "Reboot" is selected from the GUI. As a result, the power is switched off by the DAC board during the rebooting process since the GPIO pins have been improperly set as for a power down.
I wonder if there would be a way to discriminate between GUI-selected "Power Off" and "Reboot", either within the rune_shutdown script or by adding a new script that would be solely reboot-trigerred. Any suggestion would be more than welcome.
Best regard,
Lionel
Baldgreene
Postby hondagx35 » 27 Mar 2016, 00:49
Postby Baldgreene » 27 Mar 2016, 02:04
Many thanks for the quick answer and for the simple yet efficient solution. The whole power management system now works flawlessly (hardware shutdown, GUI shutdown and GUI reboot)!
Lionel
Baldgreene
Postby Baldgreene » 27 Mar 2016, 17:58
Baldgreene
Postby matlo74 » 10 Apr 2016, 14:53
Hi Lionel,
I am about to buy this dac. Have you somewhere a photo of your config ? Have you got a box from Audiophonics ? I heard they will sell soon specific box for this and a 7" display.
Best regards
Mat
matlo74
Users browsing this forum: No registered users and 89 guests
