Raspberry Pi hard drive
Re: Raspberry Pi hard drive
Postby johnbanks » 28 Mar 2016, 18:01
PeteB ...
That transformer outputs AC so an AC/DC conversion will also be required to power an RPi?
johnbanks
Postby PeteB » 28 Mar 2016, 18:32
PeteB
Postby HansBeekhuyzen » 24 Apr 2016, 15:51
Well, it depends on your car. My equipment is no secret (see http://thehbproject.com/en/About) and it might be clear that I predominantly test RPi DAC's on my set 3 (€ 99 for each speaker). A bad power supply (switching mode PSU's in particular) cause harshness in any speaker. I am working on a test of several PSU's ranging from € 50 to € 250 which will be on line next month on my YouTube channel (youtube.com/c/TheHansBeekhuyzenChannel) and later also on the site.
HansBeekhuyzen
Postby PeteB » 24 Apr 2016, 16:03
PeteB
Postby hondagx35 » 10 May 2016, 14:18
Postby rastus » 10 May 2016, 14:58
hondagx35 > Actually, that's a pretty good setup. I like it.
rastus
Postby dunghnguyen » 10 May 2016, 16:01
Congrats bro ... a lot of space that you cud dream now ;)
dunghnguyen
Postby PeteB » 10 May 2016, 17:24
I like it also (it is much more compact than my solution with the Western Digital HD).
It looks like the adapter can mount above or under the Pi circuit board? I ask this because I have a header on my HIFiBerry
DAC+, and want some access to that, so there would be no easy way to put this pcb on top of all that. In other words, it looks like it is just using the mounting holes to attach the board, and no header pins?
edit:
I am having a hard time reading the test results in the code block. I understand the first part w. hdparm, but not the second part.
Looks like dd of 1MB x 1024, but stops after 22 iterations? And the results of the read are different for the two passes?
PeteB
Postby hondagx35 » 10 May 2016, 17:55
Postby PeteB » 10 May 2016, 20:34
PeteB
Users browsing this forum: No registered users and 41 guests
