Spotify does not react [SOLVED]
Re: Spotify does not react
Postby RaspiPie » 03 Apr 2016, 10:41
Hi Frank
so I reinstalled the image. It did not work :( This is what I do after a fresh install:
I go to Menu/Settings/Features management. I click on the Spotify knob. I enter my username and password. I hit enter. I reboot. Then after the reboot I click on >Spotify< in the library. Nothing happens.
There is no spopd.log file in /var/log/runeaudio nor elsewhere.
Secondly I found that nothing happens when I go to Menu/Turn off and then click on Reboot or Power off. So I did the reboot through a shell.
What is going on ?
Felix
RaspiPie
Postby hondagx35 » 03 Apr 2016, 11:37
Postby RaspiPie » 03 Apr 2016, 11:51
Hi Frank
My browser is Firefox 45.0. I am running Linux Mint 17.3 with kernel 3.19.0-32-generic. I connect to the RP by entering the local IP adress into the browser.I have no second device in my network.
Is that all ?
Felix
RaspiPie
Postby RaspiPie » 03 Apr 2016, 12:05
Hi Frank
I FOUND IT!!!! There is a problem with the addons. I disabled all addons. Now everything works as expected: Reboot, poweroff and also Spotify!! I am really excited. :-) Thanks again a million for your support! I really appreciate it. I don't know if that helps you but I will donate to the Runeaudio project.
Felix
RaspiPie
Re: Spotify does not react [SOLVED]
Postby hondagx35 » 03 Apr 2016, 12:31
Hi Felix,
i'm happy to hear that it works again.
It would be great to know which addon it was.
Postby RaspiPie » 03 Apr 2016, 12:42
it was Adblock Plus 2.7.2. But you can disable it only for the IP of the Raspberry and everything works. So you don't need to do it globally.
Felix
RaspiPie
