Cover Art
Cover Art
Postby perryni » 08 Apr 2016, 20:50
This is a bit weird but when I use the web ui to control my tunes I sometimes see "alternative" cover art for my music. An example would be nirvana nevermind, my flacs have the standard cover embedded as metadata but rune shows a random picture of the group? Whereas when I use mpod it has the correct cover art this happens for a few more albums.
Just to note I am not complaining, just an observation.
perryni
Re: Cover Art
Postby hondagx35 » 08 Apr 2016, 21:29
Hi perryni,
i had this also on an older installation.
This should be fixed since months see .
So please tell us the version you are using.
RuneAudio searches at different places for the cover art.
- embedded (mp3 and flac)
- Last.FM
Re: Cover Art
Postby perryni » 08 Apr 2016, 23:59
Hi Frank
I am using your rp2/rp3 image from March 2016
Nick
perryni
Re: Cover Art
Postby hondagx35 » 09 Apr 2016, 01:04
where is your music located (SAMBA share)?
Are you connecting via "runeaudio" or ip address?
Re: Cover Art
Postby perryni » 09 Apr 2016, 08:38
Hi Frank
I am using a server (WHS2011) but have set up an NFS share.
I have connected with ip and runeaudio.local
perryni
Re: Cover Art
Postby jss2 » 09 Apr 2016, 12:07
Just for further information, I'm seeing a similar bug in my setup.
In my case, I'm using a Raspberry Pi 3 for music in my car (battery powered), with the latest Raspberry Pi 3 Rune image. Connecting via Wifi (with my phone also serving as the wifi hotspot). All music is on a single 128gb USB flash drive, connected via IP address.
jss2
Re: Cover Art
Postby DaverJ » 10 Apr 2016, 21:34
I'm also seeing the same thing on Pi3, but just certain albums. The files are on a USB3 hard drive. I think The Doobie Brothers albums show the group and not the album cover that's embedded.
As Perry said, not complaining - I would much rather attention was directed to clicks/pops with 24/96 files (hint). ;)
DaverJ
Re: Cover Art
Postby hondagx35 » 11 Apr 2016, 22:28
Re: Cover Art
Postby Beelzebassie » 12 Apr 2016, 11:25
Not directly related to the TS's problem, but am I correct that the last.fm database does not support non-ANSI characters?
I have quite a lot of albums with non-ANSI (UTF8) characters in their titles, and they all show up with a generic band photo.
Beelzebassie
