On executing this: echo "0" > /sys/class/gpio/gpio24/value
Nothing happens!?!?
I swapped the jumper cables for 2 new ones, they're a better fit, then i checked the rest of my connections and snapped a solder joint between the momentary switch and the mausberry! When this happened the unit turned off. When i briefly touched the cable to the mausberry it booted up, then when the unit is powered up, press the cable to the appropriate connection on the mausberry and hold for 1 sec -ish, it shuts down. So in effect it works correctly. I'm gonna re-solder a new switch. Given this behaviour should it be a latching or momentary switch?
Thanks for your help,
Dave.
