RuneAudio as a standalone system on C1+
ODROID related support
Re: RuneAudio as a standalone system on C1+
Postby pe9ghz » 25 Apr 2016, 15:26
Odroid-C1+, Sandisk uSDHC Ultra 16GB UHS-1, Odroid-C1+ HiFi shield (PCM5102)
pe9ghz
Postby jazzaj » 25 Apr 2016, 15:44
My advice you can choose the font you want, it's just a cosmetic choice for how the informations will be display on screen. Have a look to each font on Google and chooose the one you like.
Odroid C1+ (/regulated linear PSU) > Audio-gd NFB-1 (with Amanero384 combo) > Audio-gd Precision 2 > Triangle Lyrr 222
jazzaj
Postby pe9ghz » 26 Apr 2016, 10:56
I 've restarted from scratch as I'd messed up the OS when trying to solve some library incompatibilities.
Re-imaged the uSD card with the Rune Odroid-C1+ image from the repository.
Expand root partition to fit the uSD card, setup boot.ini.
Started installing the required packages for X:
pacman -Syy;
pacman -S xf86-video-odroid-c1 xf86-video-fbdev
pacman -S xorg-server xorg-xinit
pacman -S lxde
lxdm starts up on the HDMI display with a popup message about a process not attached to pid 819 or something like that but apart from this it seems to work as I see a desktop (also with auto login).
All well up to the point where chromium has to be installed. Tried to install chromium-44.0.2403.107-1-armv7h.pkg.tar.xz and also version 45 as mentioned in the Magazine. Apparently both need never versions of most libraries than the versions supplied in the RuneOS image.
Also, midori doesnt want to install (:: conflicting libgudev libsystemd).
Tried to pacman -Sy systemd but after that the system seems broken, it waits for ages upon shutdown at stopping Samba service.
Is there a more recommended way to update the OS / system libraries to be compatible with chromium ?
Or maybe just give up and wait for a newer RuneOS to be released ?
pe9ghz
Postby Dondorito » 28 Jun 2016, 10:55
So there is no Install and play image for the official 3.2 screen? Will there be one any time soon? As I understood even when I use the image for the larger screen I still won't be abled to use the player as a standalone device, since I need to zoom in first? Did anyone manage to use the buttons for zooming? Or can it be saved as default, so I can use it without pc or keyboard or even network connected?
Did anyone follow through on the implementation on 3.2 touchscreen and could upload the image... Since I won't be abled to set it up myself... Would really appreciate it!
Or is there an easier way with a updated Odroid support?
Cheers
Dondorito
Postby hondagx35 » 28 Jun 2016, 16:36
Hi pe9ghz, hi Dondorito,
at the moment it is not possible to update the C1 image.
To get a local browser working we have to make a new image.
This is necessary, because all packages (mpd, php and .....) have to be updated.
At the moment i'm very busy with other things, but will try to make a new image as soon as possible.
Postby Fujitus » 28 Jul 2016, 12:52
Hey all , I actually try too install chromium on my RuneAudio setup without success.
When I start chrunium, it said that it can't find the libavcodec.so
If you got a solution please let me know :)
Fujitus
Postby frengo » 18 Aug 2016, 12:38
Hello, since I installed the TFT, following this procedure, the TFT works but now I do not reach more Runeaudio GUI on the IP of the device. It's normal ?
It was comfortable to manage RuneAudio also via wi-fi, but now what not possible to do it. It also happens to you or pheraps is there something that I'm wrong ?...
I hope you can help me to reach my Runeaudio GUI.
Thanks in advance.
frengo
Postby hondagx35 » 18 Aug 2016, 15:21
Postby frengo » 18 Aug 2016, 17:42
Yes, I can ping it on 192.168.1.53.
In addition it can also to enter from the same PC with Putty or Cyberduck and I can quickly upload songs on the USB stick and then play them but only by TFT.
GUI does not appear on the PC.
frengo
Postby hondagx35 » 18 Aug 2016, 21:33
Hi frengo,
this is strange:
- ping and ssh work => your device has a working IP
- local GUI works => webserver and all system services are up and running (it is the same as remote but on local host 127.0.0.1)
- you can play music => mpd and network is up and running
Are you trying:
- http://192.168.1.53
or
- http://runeaudio
Return to ODROID
