IR Receiver & Remote support
Re: IR Receiver & Remote support
Postby XploD » 26 May 2015, 23:38
@hondagx35: thanks! It was problem in my case as well, now my remote is finally working :D I also got a new IR receiver and now it works much better than before on Raspbian, when I was using a receiver from an old DVD player.
@phuongdk and @mishgun: sorry for waiting, I had some work to do and I still didn't managed to fix a few bugs with my code but I'll try to write it as it is tomorrow and provide it to you so once I fix that bugs then I'll update the code.
EDIT: Here you go: lcd-display-and-buttons-in-python-tutorial-and-code-t1191.html
Music taste:
Audio source: Raspberry Pi 2 + Sabre ES9023 DAC + WD 500 GB HDD + TP-Link TL-WN722N Wi-Fi + D-LINK Dub H7 USB hub
Hi-Fi:
Mixer: Nady Audio MM-242
Misc: Tube Stereo Vumeter (Magic Eye)
XploD
Postby XploD » 30 Jul 2015, 13:55
LIRC problems again! :evil: Now I'm using RPi 2 and I can't enable LIRC. The problems are even worse than on RPi 1. Anybody managed to make it work on RPi 2?
EDIT: I managed to fix it, seems that you have to uncomment a few lines in /boot/config.txt and to put there on which GPIO pin is LIRC.
Music taste:
Hi-Fi:
XploD
Postby Dezo » 04 Mar 2016, 08:57
Dezo
Postby YannM » 29 Apr 2016, 15:05
I'm trying to install an usb IR remote but I have some issues to install lirc. I think the source of my problems is that I don't know anything about (Arch)Linux, like the structure of the files (etc/, bin/...), so I'm stuck at some steps. Does someone know a book to learn how this system works (or linux in general if they are similar) ? a chapter about the GPIO would also be welcome for another project around runeaudio and this remote.
Thank you !
Yann
System: HD -> Wifi -> Pi 3 -> Audiophonic I-Sabre V3 -> Cambridge Audio
YannM
Postby hondagx35 » 29 Apr 2016, 17:33
Postby YannM » 02 May 2016, 22:39
YannM
Postby YannM » 05 May 2016, 11:53
I followed my quest but I'm afraid to reach a dead-end :(
Apparently this remote works as a keyboard & mouse and the command "showkey" confirmed this. I didn't find online a way to "transform" the receiver as a basic IR receiver (to be used with any remote).
Would anyone have a suggestion for an USB IR receiver ?
Yann
YannM
Postby PeteB » 05 May 2016, 15:31
PeteB
Postby YannM » 05 May 2016, 17:48
YannM
Postby PeteB » 05 May 2016, 18:46
Unused buttons will work just fine... :D Is it the same DAC that Rikardo posted, here (?):
If it is, then there will be un-used pins sticking up from the dac board. You only need to find one unused pin for the data connection to a 3-pin IR sensor, the 3.3V supply, and a ground pin.
(I had to solder a small header to my HiFiBerry DAC board, you don't have to do that)
PeteB
Users browsing this forum: No registered users and 60 guests
