Turning off runeaudio and pi
Postby goldenyears » 10 May 2016, 13:33
I'm wondering if am shutting down runeaudio correctly. I click on power off from the UI and all I get are the spinning arrows - nothing changes even after waiting 10-15 minutes. After that I disconnect the Pi from the mains but am worried that it isn't shutting down correctly subsequently damaging the pi. Am I doing it correctly?
Thanks,
Al
goldenyears
Re: Turning off runeaudio and pi
Postby rikardo1979 » 10 May 2016, 13:49
yes you doing it right but it may not work for you...
Here is extended thread about same turning-the-software-off-t3470.html
rikardo1979
Postby hondagx35 » 10 May 2016, 14:04
Hi Al,
you have to watch the power and status LEDs.
RP1/2 : red (power) = on & green (status) = off => shutdown
RP3 : red (power) = on & green (status) = on => shutdown
all : green (status) blinking / flickering => active
Postby goldenyears » 10 May 2016, 15:02
Thank you both for your replies, I will experiment and get back to you once I'm done.
Al
goldenyears
Postby goldenyears » 10 May 2016, 16:41
I'm running a pi2 with iqaudio dac+. After clicking power off the red light of the pi stayed on and the green light next to it flashed a few times and was solid for a few seconds. The green light has subsequently dissapeared and I'm left with the red light.
It's off right?
Thanks,
Al
goldenyears
Postby hondagx35 » 10 May 2016, 16:48
Postby goldenyears » 10 May 2016, 16:49
Thanks Frank.
goldenyears
Users browsing this forum: Bing [Bot] and 41 guests
