USB to Ethernet adapter - how to get it working
Re: USB to Ethernet adapter - how to get it working
Postby PeteB » 11 May 2016, 16:12
Ok, so you CAN log in and run command line stuff, but not on eth1. Try "netctl status eth1"
I would try to compare the two profiles, eth0 and eth1. Run "netctl --help" and it will list some of the things you can try to do. "netctl edit eth1" should give you a convenient way to change things. Beyond that I don't have any suggestions.
edit:
oops, did not see your last post. Nice to know you found the problem!
PeteB
Postby rastus » 12 May 2016, 01:06
rastus
Postby adamk » 29 Dec 2016, 21:43
Hi! This thread helped me get my USB-ethernet adapter working, and I've seen 200Mbs+ speed now. Awesome!
However, somehow the DNS entry for 'runeaudio' maps to the old eth0 IP address even though eth1 is the only interface connected. Does anyone know how to fix this?
EDIT: looks like a combination of rebooting my routers and updating my hostname on the rune audio web app made things fall into place. All good!
adamk
Postby stosoorok » 01 Apr 2017, 21:20
Any listening tests about the sound quality with the usb to lan adapter?
stosoorok
