USB Speaker no sound
Postby pwd41284 » 15 May 2016, 09:17
Hi I'm extremely new so forgive any stupid questions.
I have hooked up a raspberry pi 2 to a set of USB speakers that have a built in soundcard to use as a internet radio. I have run volumio and pi musicbox and get sound from the speakers but decided to try runeaudio as it has better interface etc.
However in rune I can not get sound, the light on the speakers blink as they do when playing normally (speakers work fine have tested).
I thought it might be to do with i2s settings and tried to sort that but it's over my head really, on checking rune it automatically has output set to analogue but has USB in the drop down which I selected.
Any help would be appreciated
Pete
pwd41284
Re: USB Speaker no sound
Postby hondagx35 » 15 May 2016, 10:38
Postby utschu » 15 May 2016, 10:47
Did you tried to choose the correct sound outpt from:
-Menu
-MPD
-Audio Output (USB PnP sound device or similar)
Good luck.
utschu
Postby pwd41284 » 15 May 2016, 16:31
Thanks for getting back to me quickly. The speakers are usb powered and as said before that they work with volumio without needing any changes. Audio output is set to raspberry pi analogue on first boot so I changed this to usb in the drop down.
debug: http://pastebin.com/K7c3F83C
Thanks again
pwd41284
Postby hondagx35 » 15 May 2016, 18:11
Postby pwd41284 » 15 May 2016, 20:19
Sorry about that I thought they had forked off from a previous platform.
Yes I do get that notification when it's changed. I have now set the volume to start at a lower level on start.
Will have a look and see if I get any joy,
Thanks again.
pwd41284
Postby pwd41284 » 15 May 2016, 21:28
No joy so far so think I will try again in the future.
pwd41284
Postby pwd41284 » 16 May 2016, 18:45
out of curiosity I un hooked the usb speakers and connected a speaker into the jack, this time under audio out usb was not an option so prevoius speakers were being recondnised. but I could still not get sound i think im destined to not use rune.
thanks again
pwd41284
Postby hondagx35 » 16 May 2016, 21:32
Postby FerociousRA » 06 Jun 2016, 20:04
Hi, did you ever figure it out? I had a similar issue with my Logitech S150 USB Speakers. Work fine with Raspbian and Ubuntu-Mate but could not get the sound to work on rune audio.
in the webUI "MPD Configuration > Audio Output >USB Audio" without any luck. Used putty to login as root/rune then:
# nano /etc/modules-load.d/raspberrypi.conf
Place a comment symbol "#" before "snd-bcm2835" in the second line:
#snd-bcm2835
Rebooted and still no sound.
webUI "MPD Configuration > Audio Output > Volume control > enable - hardware" and manually turned the volume up using the speakers buttons, worked. Also set the "Volume control > enable - software" and still works. Maybe a glitch in the software, who knows but this thing is cool!
FerociousRA
